Optimal A/F ratios also depend on what you're running for timing WOT, and what octane gasoline you're using, if you're using an efficient intercooler, etc.hek1620 wrote:once warm it'll idle 13-14's. in gear decel(of the gas) blinks lean/air. on wot 14-15. while cruising in 5th, 13-14. no tuning has been done yet. max boost is set at 6.5psi. so is this why im overheating on the highway? remember these are not exact numbers.
hek1620 wrote:no. i read that with it disconnected u get something like 43psi. while it's connected it's something like 34psi. flamers please control urselves.
That's quality comedy right there.hek1620 wrote:no. i read that with it disconnected u get something like 43psi. while it's connected it's something like 34psi. flamers please control urselves.
the plx reads narrowband 02 voltage (0-1 volt), so it's pretty much useless.hek1620 wrote:as for not exact, i have to drive and look at the plx r300. plus the numbers don't stay still. as for setup, stock rebuild, .48/.42 t3, 38mm wg, open dump, 2.5in. d. pipe, 3in. exh., sci coil, 8.5mm wires, ngk 6re's, fat intercooler, 2.5in. piping, z32 fuel filter, stock fpr disconnected, ssq bov, stock timing, stock ecu. i think that's it. as for overheating? i've changed the water pump, taken out the thermo, flushed the system, bled it, and i run altima fans. everything seems to be o.k.. so i was under the impression that i could be overheating due to running lean. so what now?
You are correct. it has 0-5V wideband output, but also has 0-1V narrowband "simulator" output so that it can replace the stock o2 sensor if wanted.nb07bcar wrote:I thought plx 300 reaD BOTH NARROW AND WIDE. iT DESPLAYES THE WIDE BAND FOR YOUR gauge AND IT GIVE THE STOCK ECU THE NARROW BAND SIGNAL? tHAT WHAT i THOUGHT.
and it still runs...??hek1620 wrote:it's all stock. no bigger injectors, no piggy back.
haha its more like sky diving with a rocket pack strapped on but its aimed to push you to the ground faster.Jookmasta wrote:this is y ur running lean. u MUST have larger injectors than stock size. u WILL NEVER achieve a good a/f in boost unless u have an adjustable fpr, fmu, or larger injectors. realize that ur risking blowing your engine.................in other words u have a 95% chance of blowing your engine the next time you go into boost. please go and get larger injectors and an safc or emanage or get ur ecu tuned. this is equivalent to sky diving without a parachute.
yah my bad, I was thinking about an MDM techtom for some reason...and then when he said it just blinks lean (instead of giving a precise reading, like my zeitronix, which, btw, is 21.0:1 under complete vacuum and decelerating), I figured it was just a narrowband input.Jookmasta wrote:i think markemark was thinking of something else. anyways, hook up back the vac line and then run the car to see what a/f's u get around town. u didnt mention what injectors ur using and if ur using an safc or emanage or something else to control em. please elaborate on that so we can help ya out a bit further.
