i'm not trying to post bad information. all i've said here is 160psi to 145psi when he dropped oil in the chamber, if the tester was good,
eazye2000 wrote:~Typically, when you add oil after the initial test, and you get better compression, that means your rings are leaky. In your case, there was little or no change, which is awesome.~Temp outside doesn't matter. I think you want to do it with the motor just warm anyways. I don't recall.Oil will burn off after about the first minute or less of running.
dblanehopr wrote:~no, the temperature outside doesn't matter.~the oil'll burn off after you drive it around a bit.~you were basically doing a leak down test... right.....~the oil sealed the rings, gave it better compression...means you got some loose rings.
do it again, and it'll tell you if the tester is good. cuz if you do more than one test and get the same numbers, the tester is good.
i'm not sure what why we're arguing about me givin bad info.
nissan_star wrote:I think you misunderstand my situation. The first time I tested the compression, in like may, it was about 160psi all across +-2psi. I have since switched to synthetic oil and wanted to see if there was a difference, so i tested again on Dec 20. The numbers i have now were around 145 and 150, no higher, until i put a capful of oil in through the plug then they were all 160 or 161.
nissan_star wrote:~motor was ran for 15-20 mins, temp gauge was as high as it ever gets when i drive it.~Whats the throtle plate again? I did it the same way i did it in May to get my original 160psi readings
dblanehopr wrote:~he went from 160 to 145 in half a year.~of course the car's still driving great....you can't tell it's bad until it blows.~but whatever man.. just for kicks, what exactly do you think would be a good time to replace rings that are starting to give? when he's burning a quart of oil a day?
i've gone through two sets of rings given out, both on s13's... justifiably;.. it was straight bull and still ticks me off somedays. losin your 240 cuz of funds hurts. still got this one, tryin to do somethin with it. as for rings going out, just asking, what would worry you? and with him wantin to boost it? just asking?
man, i ain't tryin ta fight. wasn't in the first place. i was just talkin to the man here about his car. workin it out, ya kno. ain't gotta get hostile and flame.
Merry Christmas! ...
Modified by dblanehopr at 12:14 PM 12/25/2008
Modified by dblanehopr at 12:22 PM 12/25/2008
