SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Tue Aug 10, 2004 9:43 am
C-Kwik, not all tire/wheel assy mount up in the same fashion. Where the regular car wheel has a safety hump to help keep the bead seated properly even in low air pressure conditions...
semi truck tires do not have this feature. Very large mud tires, in 16.5" wheel selection, do not have this safety hump feature. Often times, when mounting a massive super swamper tire onto a wheel let's say, 12" wide, when uninflated the beads will sit about 4" away from the outer edge of the wheel, where the bead will rest upon inflation. Basically, it's a big gap you've gotta overcome in order to get the tire to air up. There are a number of methods to get the beads seated, but since we're dealing with such a massive tire, with lots of room for error, it is possible to blast the tire with air(cheetah beat seater), ratchet straps to squeeze the tire and lessen the gap, or other method... anyways, it's possible, after getting the tire to begin it's seating process, for the tire's bead to seat at an angle that will allow the bead to contain air, up to a point, then slip off over the rim edge with explosive force. This can happen, literally, in an instant.
So
For example (if you try this you are foolish, risky, dangerous, and do not value your life. let a tire guy risk his life, not yours) Stand next to a massive tire/wheel that is laying flat on the ground, spray lighter fluid into the gap between wheel/tire, apply the air hose to valve stem, stand back and toss lit match into the gap.
It'll go FOOP! and seal, or it'll go BLAAMMMO! and launch into the air, and could hit you or land on you and kill you.
In truth, you should never REALLY need to use this method, but out on the road without every tool, with less than ideal air pressure, with nobody to help you if you need it, one can get risky and take chances. Don't try it, just to save a few bucks. From experience, it's not worth it.
I've blown up plenty of other tires too. Nothing to be proud of. My coworker lost his jaw and half the bones in his face, had to spend weeks in the hospital, underwent several surgeries, and after two years, is finally back to his old self, almost. A 200+ lb tractor tire blew up, literally, in his face and nearly took his life. Now he has a face full of fake teeth, a jaw made mostly of steel, and skin grafts. Still worth it to change your own tires? Let us do it instead.
