How are SPL tension rods on slammed cars??
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Im about ready to order these, However now im concerned that since they are so much thicker than the rest of the tension rods out there are they going to hit the sway bar? My cars pretty low and clearance there is minimal already.. I do not have time to play around with otherwise sure id buy them myself and see if they clear... Just tryin to get feedback from anyone who has them or has seen them on low cars.
DrJuice164
Car: 04 G35 Coupe
Get it straight from the horses mouth.... call SPL or AIM "SPLparts"
Enjoy
wynnEZ
Car: 90 240 CA POWA!
PBM makes a special tension rod for slammed cars. Get it.
Philipio
Car: 96 240sx, 96 Miata
My car's pretty damn low and my beefy sway bar/Nismo power brace/SPL tension rods don't have any conflicts.
Nacho_240
Car: 1991 240sx LE
wynnEZ wrote:PBM makes a special tension rod for slammed cars. Get it.
No they dont. They are straight just like any other tension rod. You're probably referring to their toe rods.
And to the OP: I have SPL tension rods as well as the brake duct plates and the only clearance issue I had was the brake duct plates being only a couple inches off the ground. Bent the plate a little and I've been problem-free ever since. Hope that helps.
94_240sx
Car: 94_240SX
That's what I thought too. Some other companies also make bent toe rods.
OM3GA
Can you take a picture of your front where the tension rods are? I want to see it when the cars on the ground just how close is it to the sway bar, Also how low your car is..Thanks!
Philipio wrote:My car's pretty damn low and my beefy sway bar/Nismo power brace/SPL tension rods don't have any conflicts.
Do you have any pics of how low your car is? And can i see a picture of where the tension rod is next to the sway bar, With the car on the ground.Thank you!
I need to buy Tension rods asap ohmaigawsh!
Modified by OM3GA at 8:30 PM 4/17/2009
OM3GA
ohmaigawsh!
Philipio
Ok, I hope this helps you. Sorry for the picture quality. It's almost midnight and it's hard enough to get a camera jabbed in there, let alone trying to hold a flashlight on the area. Because of this, I took a whole lot of pictures, hoping that helps in some way.
This is the only picture I have that shows where my car sits off the ground. It's pretty low, but not "OMG SUPER SLAMMED."
As you can tell, clearance is pretty tight, but there is a little room. It's at a weird angle to really show the gap, I tried to jam the camera in there for a couple. I guess it depends on your sway bar and how low your car is.
OM3GA
Damn Awesome pics! I was just in a crazy car accident tonight i just got home from the hospital, basically understeer in the mountains and slide down the mountain rolled once completely and was stopped by a tree. I Was the passenger in my friends car, my side was crushed pretty bad and i broke the passenger window with my head. The car still has useable parts on it so were going to be looking for a shell. I just want to feel not sore again haha.
Anyways back to the topic, I really think those will hit on my car haha they are HUGE! and my car is lower than that, The control arms are angled crazy!
