How are S14 SE front & rear studs different?
s13eq
Hello all. I have a question for anyone who is knowledgeable about S14 SE studs. In what way are the front and rear studs different? I've heard that the knurl is larger for the fronts, but to what extent? More specifically, does anyone know the exact specs?
If anyone could help me out, I'd greatly appreciate it. I went through the search feature already and couldn't find anything specific. :)
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
Wheel lugs?... what studs are you refering to? If you are asking about wheel lug bolts, I believe they are the same.... I guess I'm confused about your question, sorry.
APEXi240
Car: 08 Nissan Versa S hatch
The studs themselves are different sizes, the lugs are not. If you put the rear stud in the front, it would be too small, you wouldn't be able to hammer it in properly, well actually you wouldn't be able to hammer it in at all. The front studs are "larger" in the back. So make sure you specify which stud you want...
I don't know the exact "specs" but if you go to Pepboys, or R&S they can tell you the exact size of the front and rears.
KSee777
If the front uses the smaler studs, then why are my front studs wiggle? One of them actually comes off
APEXi240
The front ones are bigger than the rear ones. So youre front studs probably wiggle because they are supposed to be in the rear. Change them.
