jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Mon Jun 11, 2007 5:02 am
I've been working on my headgasket and finally made a lot of progress. I had the head decked, clean the block very well, using felpro headgasket with copper spray. the first time I put the head back on I moved the gasket around barely to where I thought was a good position. Unfortunately I didn't know I couldn't put the washers on the studs while the head was on the engine so I took it off to put the studs on and put it immediately back on. Now I'm paranoid that I didn't make the same minute adjustment to the headgasket before I put the head on the second time. Now I've already tightened the studs and put the timing belt on. It's definitely not too late for me to take off the belt and lift the head off a little to adjust it, but is it necessary? The headgasket was held in place already pretty snug because of the metal pieces around 2 of the studs, plus the copper spray hopefully stuck it down. Could not aligning the headgasket with your eyes cause maybe a firing ring to be inside the cylinder and cause the headgasket to blow again in a few(maybe thousand) miles? It's definitely on the correct way I'm just curious about the little bit of play it has while on the studs.
