how about just cut off the cat?
pktj21
Car: 1990 nissan 240sx ka24e.3" jdm exhaust, strut bars F/R, home made intake,17" icw'
would it be a good idea to just cut off the cat and straight pipe it.
Vegascorbin
Car: 1990 240sx dirt track race car
#1 Don't Cut. Unbolt.
#2 Why do you want to remove it?
#3 do you hav eemissions testing to worry about in your area?
pktj21
#1 well yes unbolt the cat #2 its shot#3 no emission only safety and i know an inspector and i am just trying to fix the problem without spending a ton.
SR24DET
Car: RMS13
You can, but i would replace it with a resonator. I removed mine and it got ALOT louder. Just a FYI.
pktj21
what spec's is yours. 90 ka24e de det? or something else. you have any intake info. or any info on the 90 ka24e would help.
Gabes13
Car: rb20det s13
I have a jerry rigged straight pipe.
Is it loud? yes.
Is it stinky? yes.
Do I care? nope.
pktj21
thats about how i feel. how did you jerry rig yours? cause if i do mine i may have to use a straight pipe and clamps!
Gabes13
Car: rb20det s13
I just have a 3" exhaust that welds directly to the stock header.
Pretty much the same as cat delete/straight pipe.
A straight pipe should just bolt up though.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
you should set your self up with a header/downpipe/cat/cat back with a test pipe set up..making shure all the parts are can be unbolted from eachother..what im sayin in my round about way is..if ya had a bolt style down pipe and cat back..you could unbolt your cat and in place throw on a test pipe..per say..and use it for the track!.( uhumm ya track only!) if ya get my point..then when it comes time for your smog test..i um mean..time to leave the track..you just um bolt back on the cat and your all set..after a good freeway run of course..at um cough cough...normal speeds.
Drakelee
Car: 1992 Nissan 240sx RB20det
1986 Mazda RX7:for sale
1997 Ford Ranger:PitTruck<3
i have 3" back from the hearder, but i hallowed out my cat. loud but insectors dont relize it
nissan_slider
Car: '90 nissan 240sx
I thought about cutting my cat off but i found out that with a hollowed out cat it causes turbulince in the cat which means a lot more back pressure, in turn less power.
2ndcar
Car: 1991 240SX White 1991 240SX Gray 1995 Civic
If you want to be cheap about it just go to your local auto parts store and buy some flex pipe to stuff into the header and into the mid pipe to connect them. And remember to drive with the windows down so you don't suffocate.
livinglegend2100
go on ebay and buy a test pipe. you can get them for like $20 - $30 and it will bolt directly in.
