hurddawg »
https://forums.nicoclub.com/hurddawg-u170.html
Fri Oct 10, 2003 9:30 pm
I just swapped in SR last Sunday. It is now dead.
I'm possibly jumping to conclusions on this but I'm pretty sure of it, read the story...
I was goofing around with a friend of mine on the freeway and we had some fun (nothing stupid). We get off the freeway and the motor sounded like utter crap. It had a very loud sound like a HLA had failed, TAP TAP TAP TAP. I decided it was time to go home. I was considering at the time to leave the car (empty parking lot)where it was, but it was not a good part of town at all (DT Tacoma) so I decided to drive it home. We also didn't have a Cellphone with us, smart huh? I never had the thought that the following would happen...
About 1/2 way home while on the freeway at 60mph. I hear this light clunk adn the engine dies. I coasted to the side and tried to restart it. Sounds as if it has no compression on any cylinder, it was fast cranking and whizzy. I was praying to the car gods. I was hoping it was something like multiple rocker arm failure or soemthing, but it was not meant to be...
$136 later (towed), I pulled the valve cover and every thing looked great, the cams, timing chain and rocker arms. I checked the side of the engine to make sure I didn't blow out a rod. It was good, I had plenty of oil and coolant. Just as I was about to give up I noticed that the exhaust cam dowel pin was broken, it was now in a "s" shape-ish. The CAS drive gear is also slightly smunched too. I looked at the valve springs and it looks like all the valves (intake and exhaust) are closed (or about to be). You could also visually see that the CAS drive gear on the Cam was moved (shiny metal areas on the cam sproket).
So a $1 part killed my SR.
I have a spare exhaust cam from my g20 that I'll plop in the 240 tomorrow night and do a compression check to see if the valves are really bent. I would be one lucky SOB if there weren't.
so thats my sad story
I'll have a pic tomorrow
