pdqwrx wrote:Is that super charger a kit we can buy? If not do we know the specs so we could reproduce it.
AGM has said MANY times that this is not necessarily the best way to go. There rae reasons he went with this kit, and if you read his posts, he said it would go with a rootes type like I am building (tentatively)
maxnix wrote:Thanks for the header pictures. I always thought a 4-2-1 header would work better than a 4-1. Wonder if he has a jig?
The Impul kit has a nice shape, but when all is said and done, it still looks like an added-on kit with too many pieces and cut lines. The front is fine, but the rest looks tacked-on and not well integrated with the body. Hard to beat the natural rolled under the body sills of the G50.
I am with Jeff. I saw that exact same spoiler on a Maxima this evening. Never have understood the function of a rear spoiler on a FWD car. The OEM spoiler may not be dramatic, but it fits correctly and performs a function.
Two clicks too low on the front tires is not conducive to high speed driving confidence.
The intercooled Rootes set-up, with the necessary internal and external modifications would be much preferred. Anyone got $20K-$30K of extra cash to dedicate to get it right?
Oh, and the stainless exhaust work is immaculate and along with the headers is the most impressive modification after the Brembos.
I will agree with most of what you said there Brian. I still have yet to find a body kit for the Q that looks like it was a factory option rather than stuck on... Probably the best that is out there but not my preference...
It wouldnt matter if he had a jig really because it would have to be remade for LHD anyway!!! He told me, that it would be BY FAR easiest to get some headers made here in the states...
Youd be surprised how much the OEM Q45t spoiler reduces drag... I dont remember the exact number but its SIGNIFICANT, especially considering it doesnt look like does much... Amazing what a little thought and engineering does!!
I dont think it would cost 20k to supercharge with the roots type correctly.. Depends on how much boost you want to run.. AGM was running like 9lbs and he said he just cant get it to hook up at all, even with big 275s in the rear... I think right now he's running 8lbs..
The way I see it, 6-8lbs gives you a TON of HP (more than youll ever need), and once you take it much past that (say above 10) you run into a huge hurdle of injectors, compression and so on.. I dont see anyreason why a stock VH cant handle 6-8 with EASE.. Just a level 10 with higher stall is all you need...
If i have headers made, id probably lean more toward AGMs design.....
Heres some other helpful links...
ECU he used:
http://www.motec.com/home.htm
Place that built his headers:
http://www.exhaustdynamics.com.au/
This thread is a great read!
zerothread?id=29854
At 7lbs, he was pushing 450 CRANK HP! on his current setup..... and thats with NO intercooling, W/A injection, NUFFIN!!
His MOTEC ECU retails at about 4000!!! However, he was able to compensate for the richness the headers create and all that stuff..... I think if your into extracting every possible HP this is the way to go.. however with the headers in place and BOOST i wouldnt mind it running a little rich..
ANyone interested in this at ALL, the above thread is a NECESSARY read!!!
I think AGM took the best route, but not necessarily the most efficient route.. if your limiting your mods to the SC then the JWT boost map should be fine.....
