Let me get to the only problem I'm having after the installation. My car sounds like a damn ATOPIA car (if you ever been to disneyland you'll know exactly what that sounds like.)
Otherwise I would explain the noise as a pulsing/stuttering sound. Putt putt putt.I've read post after post, seems to me it's an exhaust leak. Coming from the bolts that weren't tighten 100% because of the welding done on the hot shot headers and my EGR valve still has 3 threads that can't completely tighten?
For my bolt problems the only answer I found was to go to a mechanic and have him grind away the welds so the bolts can tighten. Is there no other way around this? Can I do anything to grind some of that weld myself?
As for the EGR valve, sooooo many common problems of it not completely tightening, but I didn't find one answer. People said to fill it with "goo" ...but they didn't freaking name the type of "goo" that I can fill it with.
Of this mystical goo do i have to retake out the EGR valve? If so, that would be a nightmare
