If your trying to isolate the weight of the car you should of chosen an aluminum block engine rather than the KA.If your wanting to shift the center of gravity by lowering mounts than that is a different situation.SPIRONIUM wrote:I understand the driveshaft differences, i'm attempting to isolate the weight of the car so that it is a little more balanced. I will corner weigh after all of my work is done with this and other related projects and give my results.
That isn't that important either since you can import QR20 and QR25de engines from Europe and Japan..... Big bore aluminum blocks that weigh less than an sr20de..l80_240 wrote:ever thought about useing the insides of a SR18? youd spend more money getting a SR20 and new SR18 insides but hey, its a aluminum block
ca18de : 130HP@6400 SR18 : 140HP@6400 162Nm@5200 167Nm@4800
