Hotshot header for 240sx???
ComicCrime
Car: Drifting, Drag, Grip
I have an S13 with the '95-'98 motor. I was wondering which header I would need to buy for my car. Is the difference how the header bolts on, or how it runs down to the exhaust piping? I don't want to get the one for an S13 and it not bolt to the motor, and I don't want to get the S14 and it not reach to my exhaust pipe.... Can anyone help??? :confused:
NISTECH
What you need to ask your self is ,What modifications did you have to perform to get the s-14 setup to bolt to the s-13 exhaust?
typically you would want to buy to match the engine. BUT if you had to modify the header to exhaust to do the engine swap. then you will need to use those same type of mods to attach the header.
ComicCrime
Thats what I figured. I looked at both the stock headers, and they are pretty much identical. Most of the parts they make for 240's are the same they just seperate them, but I wanted to check just to make sure. I figure the S13 header will work fine cause thats whats in use now but like I said just wanted to make sure. Thanks...
