trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Thu Jun 05, 2003 2:46 pm
1) The possibly used the incorrect Oxygen sensor. The stock one should thread in just fine, if they used a smaller one it's likely it was the incorrect sensor, therefore sending innaccurate readings to teh ECU, therefore causing your computer to give you a check engine light.
2) You'll need to provide more information on where the noise is coming from, etc. Timing chain is a loud rattle from the front of the engine. More info on the rattle and we can probably diagnose...
