No problem! It's cheap, and leak proof. Plus, that way you can use the bung to adapt to other things if need be.duffman1278 wrote:Seems like welding it will be my best bet then. I'd rather just do it right the first time and be sure. I'll probably do what codyace said, and have an NPT fitting welded into it. Thanks alot
That's different. The tap itself isn't really sealing anything, it's the JB weld that is. In my first response you'll see me mentioning the epoxy method for that reason.mika31p wrote:It is really to easy to drill you just dont want to force it.. Drill the opening a bit smaller than your fitting and try to screw the fitting in work the drill point a little bit and it will go.. Then you can clean the area with a good cleaner mix a little JB weld and aply around the fitting and allow it to dry. we have done this on many hot pipes and have yet to have one leak..
That obstruction is 'moot' sort to speak, and will make no difference. No worse than a traditional hose clamp 'ridge'goalguy02 wrote:My biggest gripe about tapping and screwing a fitting into the pipe is now, depending on the lenght of the fitting, have an obstruction in your hot pipe. I like the idea of welding a bung, but with thin pot metal you have to be very careful not to melt the pipe.
