Redline240 wrote:oh, does it matter if the bov is on the hot pipe or the cold pipe?Redline
It doesn't "matter" in terms of whether or not it will discharge air, but there is a small difference in behavior. Mounting the BOV on the hotpipe gives best protection for compressor surge, whereas mounting on the cold pipe gives slightly better response after shifting. But both work well.
However in Cyber's case I am assuming he will not want to relocate the BOV to the cold side, if that is what you were getting at. For one, I get the impression Cyber is all DIY, but don't think he wants to weld stuff himself. Second, if you have a FMIC, the coldpipe will be aluminum, which is less common and more expensive to weld. That also requires buying a new aluminum flange from Blitz, and then ALSO patching up the hole on the HT hotpipe, unless he gets a stock one. Anyone with basic welding skills and equipment can move it on the steel hotpipe.
