Features:
• Lightweight, Durable 1 3/8” (35mm) Tubular Front Bar 2 way Adjustable.
• Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Specs:
Front
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear
+120, 175, 250% Stiffer than Stock G37
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
ON SALE NOW!!
Please contact me for pricing and ordering information.
Enhance the cornering performance of your G35X or G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets.
