hot wheels sixty eights 18x9 +24????
Car: 91 NISSAN 240SX
so unfortunately as everyone probably knows already these wheels only come with a 0 offset in 17s. since i wanted to go with 18s im wondering about the 24 offset. is 24 weak??? im planning on running 30mm wide fenders in the rear and 20 up front on my s13. would i have to run a spacer to get these flush????
nismofly
Car: 89 Nissan 240SX Hatch
yes, dont run fenders and theyll probably be ok, but the fenders would be pointless
no no the fenders arent for the wheel flushness. i have damage to my quater panel that i was gonna cover with a wide fender instead of fixing it. how big of a spacer would i need? also, does anyone know if the lip is the same size on the 24 offset???
nismofly
youd be a lot better off either fixing it or getting different wheels if thats the case
were talking probably close to 2 inch spacers, way too much
or if youre set on these youd be better off starting with those 17x9 +0's and spacing those out instead of these
cool, thanks for the info ill probably just go with the 17s
