Hot to properly ground a Maxima alternator ?
gallilaw
Car: 1998 Nissan Maxima
I am re-wiring a 1998 Maxima. The FSM shows that a ground wire attaches to the alternator at Terminal E. The Nissan dealer recently installed a re-manufactured Nissan alternator.
When I took a look at the alternator at home, I could not find a ground wire connected to it -- and frankly I could not see a Terminal E either. I looked at the alternator from the top and from the bottom. If there is a Terminal E I surely missed it.
The same wire bundle that contains the booted connector to the positive terminal also contains a short black wire with a ring terminal -- that was grounded to a metal fitting that was attached to some body metal, NOT directly to the alternator or to "Terminal E."
I am assuming without knowing for sure that this short black wire is the ground wire that the FSM thinks will be attached to Terminal E -- if it exists.
Can someone please help me by confirming how to ground the alternator in accordance with the FSM -- and in doing so confirm whether the black wire shown bundled with the booted connector is the proper ground wire -- and where it in fact should be attached.
Thanks.
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO.
Yes, the short black wire is the ground and it goes to the terminal that points upwards on the metal bracket. Clean the bracket and terminal surface with some emery cloth and use some dielectric grease on all the electrical connections (especially grounds).
