Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Sep 11, 2007 10:05 am
oh. it's chipped. that would have changed my answer. ECU tunes can be finicky. I don't know how long you've had your tune, so I'll assume for as long as you've said you've been running the car fine.
Even though JWT doesn't have any kind of program to cover the tune for this long, you may wanna give their customer service a call and explain your symptoms.
ECUs go bad, and ROM tunes can sometimes cause them to fail quicker. JWT is one of the best in the country for chipping, but it's not to say that even they are infallible and didn't cause premature death. But that's the risk you take when you have someone solder your ECU.
Normally if you had eliminated mechanical problems, I would start in on electronic diagnosis, and I usually suggest trying someone else's ECU to see if yours is on its way out. Given ECU retunes, though, that's not as easy a proposition as it would be with a stock setup.
So I would check your fuel pressure first, eliminate any kind of mechanical failure and then contact JWT and explain the situation to them and see what they can advise you to do.
