RS12Turbo wrote:hmmmmm, I have all this stuff left over from my clip.......so now the word is it's best to leave hooked up? When I asked a few months ago, it seems like I was told it was easier and not needed to have it hooked up, and was given a vac diagram to use without it.So, you actually gain power leaving it hooke up? The butterflys don't function properly when hooked up using the simple vac diagram thats posted up?Hmmmmmmm, i'm confused
It's 'easier' to not do it because not doing things is always easier than doing it.But the proof is in the pudding my friends.
Disconnected:
http://www.westd.ca/gallery/di...pos=2
Connected:
http://www.westd.ca/gallery/di...pos=3
now.. I had a problem where they didn't OPEN EVER which you can see in the 'connected' graph..Also the 'connected' graph is at 16psi vs disconncted @ 14.5 but since it's a T3 turbo you KNOW i'm not making full boost at 3100 where you can CLEARLY see the benefit of the system in action.
Btw if you click the pic you'll get a better full rez version.
It's not that they 'don't' work when you hook them up directly, it's that they don't work the way they were intended to work..When they go from seeing vac at idle and then pressure at anything above it they are pretty much just open ALL of the time.I also found that my car ran a LOT better with them disconnected than with them BYPASS connected (i.e. directly to the intake). When it was connected this way I found the car did weird things when transitioning from vac to boost.And of course it ran BEST when they were connected the factory way. (They just didn't open at high rpm..)
