Hot rail / fuel issue
A home for 1983–1989 300ZX owners!
Phram1
Car: Turbo D21
My EMS does not have the software for fuel temp like the stock ecu so when I turn the engine off for say 15 minutes, the rail / fuel gets hot. Then starts require 3-4 minutes of idle before the rail / fuel is flushed and the fuel returns to a normal temp.
So, has anyone have a solution to this issue?
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
What car? What motor? Turbo or not?
Phram1
Car: Turbo D21
88 300zx. VG30ET
z31na2t
Car: 1986 300ZX TURBO
I don't have a FTS or the FPR solenoid. Never have an issue. I think your problem is elsewhere. You should have warm start enrichment tables of some sort, you need to work on your tune - as theres more to it than just the base maps.
Phram1
Car: Turbo D21
The warm temp fuel values reference the water temp and air temp. These parameters are correct. If I change either of these values then the engine will run very rich once the cool fuel has flushed the rail. Hmmm what am I missing?
camarokid
Car: 1986 Nissan 300zx
1997 Chevy Camaro
1982 Chevy Camaro
1969 Chevy Nova
the 280zx turbos had a fan to keep the injectors cool so maybe you can get one of those 'eletric superchargers' off ebay and rig it so it blows on your fuel rail. or you can try a heat wrap on your turbo.
Phram1
Car: Turbo D21
z31na2t wrote:I don't have a FTS or the FPR solenoid. Never have an issue. I think your problem is elsewhere. You should have warm start enrichment tables of some sort, you need to work on your tune - as theres more to it than just the base maps.
Just to verify, are you running a stand alone EMS rather than your stock ECU? Also, note that the issue does not keep the engine from starting. Its only that my AFR are very lean until the fuel rail cools off from new fuel from the tank.
z31na2t
Phram1 wrote:The warm temp fuel values reference the water temp and air temp. These parameters are correct. If I change either of these values then the engine will run very rich once the cool fuel has flushed the rail. Hmmm what am I missing?
Warm-start enrichment goes away after a short period of time, and the system should revert back to base maps, after idle tables, etc. You don't fix this issue with changing the base map. There are enrichment tables for different periods that modify the base map depending on the condition. These are where you need to look. What EMS are you running?
I am running a stock ECU with Nistune, but the only sensors I have are MAF, CAS, TPS and CHTS.
Phram1
Car: Turbo D21
Would I be correct in saying that you are running the stock fuel pressure regulator and have removed the FTP from it? I have limited experience with Nistune but it appears there are parameters that exceed the EMS I am running.
I am running an SDS EM4 which has limitations. I can only adjust the start temp values - air temp values - engine temp values. As I had mention in the begining of this thread, it is only a nuisance for about 3-4 minutes.
I am looking at upgrading my EMS to a Vipec i44. I expect that it has the range and parameters to alleviate this issue. Your thoughts?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'm running megasquirt on a stock fpr and a stock fuel rail, no problems, you need to figure out why your fuel is getting so hot, you have a clogged or kinked return line?
Phram1
Car: Turbo D21
evildky wrote:I'm running megasquirt on a stock fpr and a stock fuel rail, no problems, you need to figure out why your fuel is getting so hot, you have a clogged or kinked return line?
I will investigate the return line for issues.
Since you are running a megasquirt, this would mean that that your stock ECU does not interface with the megasquirt and therefore the fuel temperature sensor that screws into the fpr is not activated, correct?
evildky
06 Nissan 350Z GT
I have no factory ecu or harness. the fuel temp sensor is still screwed into the fpr but nothing is connected to it.
Phram1
Car: Turbo D21
Thanks for the confirmation on the fts.
I will check into the blockages in the return line in the next day or so. I will let you know if it is.
If it is not blocked in any way, then I will know One solution would be to move to a better EMS. As mentioned in a another post about an interest in the Vipec i44.
thanks for your help.
Return to “300ZX (Z31) Forum”
