05G356MT »
https://forums.nicoclub.com/05g356mt-u186732.html
Tue May 13, 2014 12:59 pm
So took the G out today and otw back it overheated. Recently I had the rad pulled and all new fluid put in and new lower hose, ive bled the system using the screw in the rear hissed this sputtered then I shut it, it runs cooler at speed but at idle you can watch the needle climb... upper hose is scorching hot. Im thinking Tstat any other suggestions on what to check. Currently im letting it cool so I can pop the cap and see if it bubbles up front. Also the fluid in the resi is staying midway between min/max...
