go to an hvac supply store and get some insulation - 4-6" wide and wrap it arund the aluminum pipe - the higher the R value the better the insulator, just make sure it can stand up to engine compartment temps.johnnyd6404 wrote:I have noticed that my intake pipes are noticably hot. Is there any good insulating wraps or somthing to keep the two pipes cool, or does the pipe being hot not effect the performance. I have noticed some power loss after driving for a long time, but it could just be in my head. Any input or products would be great.Thanks
i'm still skeptical about that. i actually want to see those logs.allensteiner wrote:nope...it sucks hot air straight from the hot radiator. that's a wai - warm air intake fenderwell intake is a fwi and it's not really a cai either. if you run your pipes into the bumper and insulate them from heat so you get colder iar in - that's a cai. don't worry though, unless you have a turbo and the air goes thrugh an intercooler it's always going to be warm. there was a write up here somewhere where a guy cut out parts of his stock intake box to make a heatshield and wrote that his intake air temp dropped from 100+F to 60-someF - look around for it.
i found it! here you go: zerothread?id=281291
Modified by allensteiner at 6:33 AM 6/6/2008
I partialy agree with you the plastic stays cooler but it deffinatily does not preform better. I have much better response and power not to mention the sick sound it has so stock is restrictive as far as I am concerned.G4nismo wrote:injen FTMFL!
go back to stock
Modified by G4nismo at 12:09 PM 6/6/2008
yea your right about sucking hot radiator air but i dont think that set up will work were mine is sits vertical I saw that injen makes a heat deflector but its polished aluminum so that wont help much. Oh well it still sounds nice just was hoping to squeeze some more out of it. I will say that I did get about 5 percent increase in mpg city and almost 20% highway so it was worth it for me. Plus who doesnt like that growlallensteiner wrote:
def does not perform better? are you serious? YOU THINK you have better response and you THINK your butt dyno tells you have more power all prob because of the name brand that you paid $$$$ for and that stupid it makes. its been debated and proven before and injen is one of the worst CAI you can get. CAI's are just commonly known as noise makers. sorry buddyjohnnyd6404 wrote:
how is it so restrictive?DevonD wrote:Yeah I agree. You MIGHT be getting cooler air with the stock box but its so restrictive it ruins it.. with the cone filter or WAI settup your getting way more air but its also warm air.. I think the WAI has a slight advantage over the stock box.
the snorkel is designed like that to actually "ram" air into the airbox.and there have been reports that the stock resonator/accordion tube helps low end throttle response, as well as the snorkel.DevonD wrote:well i mean think about it.. its sucking air in from a maybe 1 inch tall slat thats jammed up against the hood, and it does work just fine. Im just saying having a gigantic cone filter is better than a slat under the hood. And if im wrong please explain Dyno results to me becasue they point to the same conclusion. They might not be huge gains but its somethin at least.
And if you were to remove that resonator box you would be oppening up the intake pipe to that warm air behind the radiator through the L shaped pipe on the bottom side.. so doing the same thing as a WAI...
i'm not a chick. and i was trying to make a point and save you some money but whatever, do what you want.johnnyd6404 wrote:Damn whats up with this chick I'm not tryin to debate the performance of it I was just looking for something to keep the pipe cooler. Chill out you dont need to be so nasty, sh** everyone has their opinions but damn
