centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Wed Sep 27, 2017 1:09 pm
Hey Val. I think hose replacement isn't a maintenance item, it's a repair, so there is no list of hoses or mileage. Take a look in the manual though, I could be wrong.
I know rubber doesn't last forever (maybe 7 years) and most hoses are mostly rubber. There is a rule of thumb that people have saying to replace hoses at 4 years, because they are subject to chemical and heat exposure and you want to be safe. I know for sure that many 'normal' people don't actually do that, especially with all those rubber vacuum lines stashed way inside the engine bay. I've replaced hardened hoses that were 20 years old, not because they failed, but because I was already in there doing other things. Others say, when working in an area on other maintenance, replace the hoses since you're in there. So, you get your coolant flushed at say 100,000, maybe replace those coolant lines. Having your throttle body cleaned? Maybe replace PCV, valve cover and vacuum lines nearby. I kind of agree with that and it falls in line with what Ilya says, because you're in there and you are actually inspecting the hose.
