MrSag »
https://forums.nicoclub.com/mrsag-u18010.html
Mon Sep 20, 2004 1:11 pm
I'm basically responding to the post started by PoorManQ45. No flaming or even overzealous venting, I just wanted to get some facts straight, and propose a few ideas. My previous car being a '94 Caprice 9c1 (police), let's get the Caprice facts straight first:
1. Police Interceptor is a code name for a police Ford Crown Victoria, and has nothing to do with a Caprice.2. Police Caprices are called 9c1's. Don't know why, don't ask.3. 94-96 9c1's came with optional 350 ci (5.7 L) V8 engines. They're called LT1's, and are the same engines found in the same year Corvettes, Camaros, and Firebirds.4. A stock LT1 produces 260 HP, 330 Lb/ft torque. All of the torque basically available from 0 mph. With the right tires, it's enough to tear up the asphalt. Figuretifely speaking. Seriously though, don't try to race a Q (G50 in particular) with an LT1 Caprice intending to win; that's just silly. But enough ranting:)5. 9c1 Caprices and Impala SS are nearly identical, with the exception of body trim, leather interior on the Impala, wheels, and some minor differences in the engine bay... like hoses... but we'll come back to that later.6. Both 9c1 Caprices and Impala SS's have braking problems. It's true. It is not, however, due to bad pads or rotors. Those are fine. The main problem is that the car originally had drum brakes in the rear. When the above mentioned models were released, rear brakes became disks. But the engineers didn't bother to review the braking mechanism, which was intended specifically for use with rear drum brakes. Commonly reffered to as the "proportioning and metering defects", it rendered the rear brakes virtually useless. All of that can be fixed in about 10 minutes, with a set of tools, a bolt, a nut, a rubber washer, a small file, and a can of fresh brake fluid. Needless to say, I fixed it as soon as I could get my hands on the above objects. The result? Much better, but still very iffy. The second problem? Brake pads or rotors? Nope. Suspension. The stock shock absorbers are way too soft. That caused the car to perform a nose dive when braking hard, thus reducing the traction in rear wheels. Solution? Bilstein Sport shocks. And to make it all worth while, good tires. Those three modifications will put a Caprice somewhere on par with a G50 (The Q does have awesome braking, can't argue with that). The Caprice will now also out-handle and out-corner a (stock) G50, 10-folds. Now, I'm not suggesting you go buy the cheapest brakes and rotors you can find, but I just wouldn't want to spend a lot of money on a name brand and not consider cheaper options, because in buying a name brand I'm mostly paying for the brand's name. Don't skim on the tires though. Every time you want to consider a worse tire, keep in mind that the tires are the only parts which make, or should make, contact with the road and hopefully keep you on it.
Ok, now let's get back to the hoses. The great big difference between a 9c1 Caprice and an Impala SS, is that 9c1's have silicone hoses, and SS's don't. Silicone hoses will last a lifetime. And I'm not even talking about the car's lifetime. Not a myth. I'm an eyewitness to that. The car could be nothing but a pile of rust, but the hoses will still be good. So, why don't we (and by "we" I mean "not me") make a hose kit for the Q that's made out of silicone? And on top of that, make it cheap? It'd make a lot of Q owners happy campers.
