Plenum removal/cleaningKnock sensorsvalve coversfuel rail flush
After of couple hard runs, Ive actually seen a little smoke coming out from the hood..... Pop it open, and its from the valve covers....... Plus, it occasionally reeks up the cabin when im sitting in traffic..... Only happened 2 times that I can remember.......
And just so you know, I did a search, and most of the posts are related to pre-94s, with all the RTV crap......
So here's my Qs......1. Is there anything special about doing the valve covers2. whats the best way to clean the valve covers (i have access to a shop parts cleaner)3. Can I clean up some of the varnish on the heads while im in there?4. Is there anything else I should look into while doing the valve covers (FYI plugs have been done about 2000 miles ago)
Also, since Id be doing the plenum, I need to think hoses..... At the meet, I talked with Fred, and the hoses looked ok..... The hoses I have removed are the hose going into the thermostat cover, brake booster hose, and the vacuum hose underneath the intake hose, near the TB...... All of these hoses looked pretty much new, very soft and pliable..... No signs of interior rotting or anything..... The brake booster hose was a little hard, but looked OK inside...... Ill probably replace that........
