Some of you have already chime in my previous thread regarding the early cut-out issue:
zer...age=1
After doing some research on the Horsham chip, I decide to give a try since i am running the exact mods needed for the Stage 3 chip. Its program is designed for running bigger fuel pump, while maintaining stock FPR. I figure this chip should be the link I need to get the car running properly.
So I installed the chip today, hoping it would bring an end to the cut-out issue which has been happening. The car started up just fine, and the power is noticeably better at each boost level (7 to 12psi) than I was running Power FC (map not fully tuned). The car never felt as lively as before, the power is much smoother and stronger with this chip.
I increased the boost to the 13psi and floored the throttle at 2nd gear, the power was there as it pushed me from the seat but once i hit 6500rpm it cut out on me again!!! I tried increasing the boost to higher level, the cut out comes on even earlier!
At this point, I'm getting quite paranoid because I have already tried a few things that comes it mind: ensure there's no boost leak, gapping down the plugs, better coils (FET coil pack), ideal ecu chip.
However, the problem never got away! There must be something I've overlooked, but what could it be?
On the bright side, the Horsham chip is giving me a lot more power for daily driving. But the cut-out issue really destroys the fun when you step in the throttle. Besides, I have already purchased set of HKS cams. Its really a waste if I cannot rev the motor up, hopefully you guys can help me dig out the problem.
Here's my mods list:
Z32 MAF444cc injectorsGT28RWalboro 255Blitz ID-color boost controllerBlitz gauges (pres, EGT, boost)FMICTubular manifold3" turbo backHKS filterFET coil pack
For more info on the Horsham chip, refer here:
http://www.h-dev.co.uk
