horsepower guestimations
Sil80315
Car: 1991 Nissan 240sx
Ok guys im sure this has been reviewed before but lets see some numbers. motor is already built and i plan on taking it to the dyno in another week or so
s13 blacktopGTI R T28555cc injectorsRom tuneHKS step 2 264 camGreddy intake manifoldMegan exhaust manifoldFull three inch exhaust turbo backMegan FPRwalbro 255
I plan on running the turbo at 18psi for the dyno pull but wont be running that psi for daily
So far ive seen one or two cars reach 330whp with this turbo from a stock motor and if i could reach that then id be very happy
thanks
mRodiek
Car: Stock Hatch
At least 300, 330 is definately possible, IMO
240_SeX
Car: 1992 240SX SE
We have nearly identical setups, i will hit the dyno in a month or so, very intereasted to see what you get for numbers.
I have seen as high as 348whp on pump
SlideWayzS13
Car: 89 S13 coupe Swapped srBlkTop
Im gonna say 315-320 to the ground. Will be a very fun setup.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
It depends on the efficiency of the rom tune. I would think you could hit what the turbo could flow. 300 to 350WHP maby.
What FMIC are you running?
Sil80315
yeah if i could make 300-330whp that would be kick a**. I don't picture any more then that so anything above 330 is a bonus.
Im running a greddy FMIC. im also going to be using a safc for fine tuning.
