horse power?
blusilvia
Car: 1995 blue 240sx w built sr20det
Does anyone know approximately how much horse power I can hit with a HKS 3037S 56trim turbo with FR manifold and external wastegate? It is the T3 flange. Also what boost should I run?
I have a fully built sr20det with CP pistons 87.5 , Eagle rods, Calico main and rod bearings, Arp studs, Cometic head gasket.
Head has greddy springs, titanium retainers, Hks 272 intake and exhaust cam.
I also have everything to run this setup like 72lb injectors, Z32 MAF, E-manage etc.
I just am not sure how much boost to run and how much wheel HP I can hit? Any expierence?
namwons_240
Car: 97' 200sx ser
well if u dont know how much boost to run and how much hp to expect that means u havent tuned your setup. SO GET TO IT...j/k, but seriously 450+hp should be no prob for u when tuned.
Nismo_Freak
Car: 89 Nissan 240SX
1 BAR would be safe on pump, just depends on your tuning.
You will need to just get it together and do some dyno runs to see where you stand. When you build an engine there are alot of variables that change power production.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
timing is going to play a big role, especially if your running straight pump gas
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
E-Manage is only a piggyback, correct? What else are you running with the E-Manage?
drifter_for_life06
Car: Daily: '16 WRX
Exocet
correct, e-manage is only a biggyback therefor limiting the amount of tuning capabilties it can work around
i read somewhere that anything above 740cc injectors the emanage isnt going to help, and a standalone is needed
