wrxkyle »
https://forums.nicoclub.com/wrxkyle-u145821.html
Tue Nov 03, 2009 9:41 am
so my 93 240sx(sr20 coupe) rolls completly normal at very low speeds, but at around 25-35mph it vibrates in a way that shakes the whole car, seems like it is comming from the back. it's on coilovers(apexi) with 18" rims and is low to the ground, but i can't figure out what it is, once i get above 30-35 it's gone, only shows up at that speed. i'm really stumped on this one, as even at 90mph i don't get anything. almost feels like when you gas it at 1k rpms and the engine runns super rough till it picks up, but this is not the engine, i have the clutch in and the car in neutral and it's still vibrating, what suspension issue should i bee looking for?
also does anyone know the "correct" size crush washers for the turbo oil feed line banjo bolt on the block? that thing is leaking like a siv. i think that has been taped and helicoiled as well, anything i should know about those when it comes to torquing downs things? are they weaker than an original tap?
