horrible stuff happening way to late!!
CRyan
Car: 1997 Nissan 240SX
I've bought an aftermarket header and have run into a problem. I get under the car, the header is basically ready, and I go to screw in the OB sensor and guess what, the hole that it goes in is about the same size as the hole that the O2 sensor goes in. So were going on, its about 135 here, and we are trying to make a fitting for a temporary fix. Anyone else had this problem before while installing?
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
are you sure you arent trying to put it in the EGR hole?
CRyan
ok, we made the alluminum fitting out of a adapter for some nitrous stuff laying around, but its alluminum. I need to know where we can get a stainless steel adapter that will hold up. . .and to answer the egr answer, were positive this is where it goes!
