Two Fowty »
https://forums.nicoclub.com/two-fowty-u120229.html
Tue May 12, 2009 3:32 pm
1989 240sx. Alright. Here's the story. Hooked up my stereo, amp, and subs.. Worked for a bit, switched amps, subs dont work and go into protection mode or just blare random bass and hit crazily. Switched back amps, same problem. Switched decks. Couldnt get new one to come on. So I tried hooking up the old deck and now it wont work at all.
I'm almost positive everything is hooked correctly. Only hesitance i have is with a wire coming from the deck labeled P. Cont. I'm not sure where it goes. The manual says "Connect either to the power control terminal when using the optional power amplifier, or to the antenna control terminal in the vehicle." I currently don't have it hooked to anything and i dont remember if it was in the first place.
The small wire running from my amp to the stereo (not sure the name) is currently hooked to a wire labeled "Amp turn on" , and it is on the bigger of the 2 plug ins of the wiring harness.
Any ideas would be great, I dont even care if the subs and amp wont work, I just wanna get my stereo running. I'm getting fed up with 240's and their pathetic reliability for anything.
Modified by Two Fowty at 7:35 PM 5/12/2009
