DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Nov 13, 2006 2:53 pm
okay, what happened leading up to this?
because it really sounds like you spun a bearing, but its hard to tell from jsut those short videos you know?
i didnt idle higher when i psun a bearing, but it did run and rev fine, just power production was down a very little bit, and that noise was constant.
it sounds like a hammer on an anvil does it not?
i cant really tell anything from the pictures, but i dont want to scare you. it could jsut be that a guide has broken and is causing that problem. i noticed you still have that upper guide, that should have been removed long ago, but thats probably not the problem.
so it could be a spun bearing, broken guide, or something entirely different that is too hard to hear from thsoe clips. if you could, definately let us know more about how it feels, drives, happens, what work you did to it leading up to this, and how/when this started happening.
