I really appreciate the feedback! I feel like I've tried everything, and I can confirm that getting up to cruising speed quickly definitely makes a positive impact on MPG, especially since I have an "X". Most of my miles that I'm putting on my car are city miles in Philadelphia, going to and from work, but theres also some highway miles once i get in to NJ. If i calculate my mileage while only driving in the city I average around 12MPG. I just didn't think that 12MPG was normal even though its all city driving since the car is rated for 18MPG city I believe. My previous vehicle was an Escalade so I'm not really complaining about getting horrible MPG because i don't want to spend the money. I knew when i got this car that it wouldn't be an astronomical difference in MPG and since gas prices dropped big time I'm still happy with what I'm spending now on gas compared to what i was spending. I'm more or less just worried about the car and if something is really wring or not. I am meticulous about my cars and I baby them big time, so whenever anything is wrong with them it drives me nuts and i fix it right away. But this is a noticeable problem I've been facing ever since I got the alignment and installed new tires because I dropped 4MPG.EniGmA1987 wrote:Well you said you are driving slow, the lower gears dont get the greatest MPG. I found that a 50mpg cruising speed got the best MPG because the car is able to get into 5th gear there but RPM is also pretty low still. If you are under that speed on streets then you are in lower gears with higher ratios. I also found that accelerating somewhat quickly up to speed so that you can be at cruising speed for as long as possible was far better for MPG than doing what 99% of the population does with taking an the entire time to the next signal in a constant slow acceleration state.
Heavier tires can also decrease MPG, but Id only expect maybe a 1mpg difference from tires. I noticed that going 3lbs heavier on each rim actually dropped my MPG by 2. A bad alignment could also drop the MPG a little bit. Really there are just too many variables to tell you that "the problem is X", and most likely it is a lot of little things adding up to a lot.
I keep up with the required maintenance pretty well. I change the oil with full synthetic every 3500 miles and i also change out the PCV and the air filter pretty often. I put new plugs in about a year ago, there was a tiny bit of oil inside one of the tubes, but i don't believe it was significant enough for me to change the valve cover. I have also cleaned the MAF, although i haven't tried replacing the OEM gas cap. Could a new gas cap make any difference though?CPJ LB wrote:Just curious, do you change out your air filter on a regular basis? also other maintenance upkeep will keep the car running good. oil changes, PCV valve change, spark plugs (also check for the dreaded valve cover leaks where oil gets into the spark plug tubes), replace gas cap if you have high mileage on your M (with only OE Infiniti M gas cap), clean MAF (mass air flow sensor)...
I add Redline fuel system cleaner in my car at every oil change and take the car out on the hwy for some quick runs to help burn out the gunk...I feel the difference afterwards.
My car is modified and I'm averaging close to 17-19 mpg (city/hwy combined) while in my "aggressive sport" tune. And I keep close to the maintenance as possible.
Thanks a lot for the advise! I don't mean to sound like an idiot but i just want to clear one thing up that I'm a little confused with lol. So I understand that a newer OEM gas cap may seal tighter and that a loose gas cap is probably what caused my SEL light to come on. But the light went off on its own and hasn't come back on, so the SEL light isn't the issue. So are you saying that replacing the gas cap with a new OEM gas cap could potentially increase MPG and/or be some of the reason my MPG is suffering so bad?CPJ LB wrote:^ good work on your car!!
Yes, a new OE gas cap will work perfectly. I went thru a similar experience and I replaced the old OE gas cap with an aftermarket gas cap -- about a few weeks later I noticed that it wasn't sealing tightly each time I would put in gas. I picked up an OE gas cap from the dealer and no issues/codes... In fact, I have to use effort to twist off the new gas cap each time I go to fill up![]()
big difference...I still had the old OE gas cap in my garage and compared the old vs the new...the rubber gasket on the new gas cap looked more sturdy and was thicker.
I'm glad you said that, because although I'm far from an engine and performance guy, I can never buy into those too things making a significant difference from an overall well maintained car that is not pushed hard. I guess it could help in the office really health of the engine, but not make a difference like in erasing 2mpg or so. I'm wondering if all the guys with 16+ mpg have tuned cars.ross6200 wrote:Other than that, I recently did a major service at 110,000 miles, including new filters and spark plugs. That did nothing to improve my mileage.
