AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Mon Dec 30, 2013 10:57 pm
Standard stuff... Got the FSM?
IIRC, those suffered from horrible FE when they had issues with the ignition (secondary coil) - Check spark from both, and ohm out your plug wires (they don't last forever). After a full tune-up (including compression test), check the AIV (they clog) and the sensor at the manifold, and also check valve clearance (hot). Check the 2 terminal water temp sensor. Tons of variables, any of which can really impact FE.
