goshoryuken »
https://forums.nicoclub.com/goshoryuken-u4208.html
Sun Jul 06, 2003 3:54 pm
Okay, well here's some information that might help narrow down the problems. The spark plugs and wires are both Autolite's. I know NGK is the best, but the guy who sold me the car had put in brand new Autolite plugs and wires. My mechanic said there weren't any leaks anywhere, but then again . . he is an idiot. I have no radiator over-flow coolant, because my radiator over-flow coolant bottle has a huge azz crack in it, the car has received an oil change, I bought a brand newbosch o2 sensor but that one's probably still in my old engine, I dont know about the fuel filter, and I don't know about the distributor rotor or cap but the car turns on fine every single time, I don't know about the injector cleaner, vacuum leaks, bad fuel pressure regulator, tps, or the MAFS. I think the MAFS is okay, but then again the guy who sold me the car put some busted "custom" magnaflow intake on it, with a custom extension down to the front of the car, and the filter on it seems pretty dirty to me. So basically I should....
Purchase:1 - A new coolant temp sensor2 - A new o2 sensor3 - new ngk ir plugs4 - new ngk wires5 - new fuel filter6 - a replacement over-flow tank so i can have coolant in it.
and check:
1 - for vacuum + injector leaks2 - tps and mafs carefully3 - distributor cap and rotor4 - the fuel pressure regulator5 - the injector cleaner
I will purchase what I need when I get paid, as for the rest . . I will check that in a few minutes as to the best of my knowledge. I'm somewhat of a newb at this so I might not catch it the first time. If you guys have any extra help or suggestions . .please post!!!!!
PS - Could the lack of a radiator over-flow coolant in the cracked coolant tank be causing over-heating under the hood and bad gas mileage?
PSS - If I can't solve this problem myself, what should I do or who should I go see? I'm sick of taking it to a mechanic and having him say it's okay . .because 10 - 15mpg is obviously not okay!!
-GoShoryuken
