Horrible gas milage and rev to 4k blue smoke.....
w1ngzer0
Car: Pfft. i don't own a box
what the hell does that mean,.....
navysnail
multiple problems, posibly your maf isnt giving a good signal, or no signal at all, tty cleaning it, wiggling the harness, and making sure the ground has less then .02v difference from the negative terminal of the battery.
as for the blue smoke- your burning oil, check the oil every week at least, and make sure to keep changing the oil and filter every 3k
w1ngzer0
i do a regular oil change and filter change... Ah blue smoke means oil. Bad and normal for me. Before my engine was worked on oil would leak into my exhaust piping and sit there.... So it could be just burning off the crap inside.
But i'll check just to make sure. Maf isn't giving a good signal would make sense. That might be where my short is. I'll check all this soon. Thx for the insite
navysnail
np man, also check the coolant temp sensor, if that goes bad it can do the same to your mileage
i just say to continue to do regular oil changes because many people seem to think if they are burning oil, they are constantly adding new oil and therefore dont need to change it.
w1ngzer0
lol, no problem. Nah i know i need to change the filter and oil due to it's just reciruclating the same crap over and over lol
Coolant temp sensor? the thrmostat was rusted over when my head was worked. So they replaced that. Where is the coolant temp sensor at? I know the maf is that big electronic plug on the intake..
navysnail
you can spray the maf out with some brake cleaner, but be careful, those wires inside of the sensor are very fragile!
the coolant temp sensor is located on the intake manifold, it will have a red plastic piece, and it is near the top of the engine, onthe part of the manifold closest to the front of the car. you can check its resistance, it should be .33 kilo ohms? its .33 somthing, just make sure it has somthing like that when the engine is warm
w1ngzer0
okie dokie. I will check this all out tomorrow which is friday!
w1ngzer0
well, cleaned out both mafs. I forgot to hook up the 2 vacuum lines so it kept stalling and spitting blue smoke. LOL
I don't think smoke is oil. WHen i was eating oil it was white. Local mechanic said that was fuel.
So, anway. I changed the filter and cleaned the sensors and the tubes. It idles a lot better and rides smoother with less backfire. So, hopefully this will increase my gas milage back to at least 300 per tank.
Dirtylou
Car: 1991 Nissan 240SX RMS13
I've always heard blue is oil, white is anti-freeze and black smoke is rich.
DAEDALUS
Car: 1990 Infiniti Q45
True, black smoke is rich, but if the fuel is dumping from a large leak, it'll look a lot like coolant. Huge white clouds, smells like fuel. Pretty dangerous. Always heard oil burns dark blue as well, never heard of/seen white for oil.
s13sr20chris
those are the typical colors though i have seen some dummy smokes. like white for a rich or grey for coolant. cars are funny. the smell of the smoke is what really gives it away.
w1ngzer0
but 240sx kid thx. cleaning the sensors and changing the air filter changed a few things feels better thats for sure.
I'll give you an update if my gas milage improved any..
xTearsFallForeverx
Car: 1990 s13 Fastback
also maybe replace your o2 sensor
w1ngzer0
well guys nothing worked. My o2 sensor was fried thats why there was smoke comming from the signal wire that you plug into the o2 sensor. I guess something screwy is going on with my stupid car
Still bad gas milage, i sent it to a shop. Hope they can fix it.
The Mic
Car: 3Z Wmb
you couldve waited for my advice, bastard.
w1ngzer0
S13GUY wrote:you couldve waited for my advice, bastard.
lol this is a 3 weeks old post.
What could you tell me thats causing everything to short in my 240sx?
The Mic
Car: 3Z Wmb
check your thread, answered.
w1ngzer0
which thread? Not in this thread becuase i only see your 2 posts
The Mic
Car: 3Z Wmb
http://www.nicoclub.com/zerothread?id=100445
My advice: check your fuse box, inspect all fuses esp. the "electronics" fuse.
