Horrible bumps!
FahwadDeBass
Car: 92 240SX
i just instaled some Tokico HP struts and some Intrax springs on my 92 240 fastback. im having a problem with the top washers on rear stuts hitting the wheel well and making driving unbearable and probably dangerous. i put everything back on that was on the stock s & s...was there something i missed? is there anything that can fix it? i have a 6 hour drive back home tomorrow and i dont know if it will mess something up badly or just drive me crazy.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
are you absolutly sure you put everything back on? The first time i did my suspension, i missed a rubber spacer that was supposed to go back on. the first little bump in the road i hit sent the rear bouncing up and down like an old worn out caddilac. Double check and make sure there arn't any parts you may have moved out of the way and forgot about. If its not that, how do the mounts look, is the rubber worn? It will bulge up when the car's weight is resting on it if it is.
