Other than PIAA not many car horn web sites have MP3's of their various model horn sounds. I would have used the PIAA 400/500Hz horns but for $60 and so/so reliability reviews I just went with the basic HELLA 012010971 twin 400/500Hz kit for $30.
I reused the stock Path horn brackets on both and pig-tailed the negative to the mounting bolt. Soldered up negative pigtail connectors and slathered silicone grease in / on all push in / bolt on connections. Used existing OEM single wire push on connections for positive.
Dirt simple install (if you don't choose to do it outside during a downpour) but the 2nd (high) horn under battery fuse box requires unbolting surrounding mounts on fuse box and/or battery / fluid reservoir to allow hand room.
Sound of Hella's is 'adequate'.
