Horn works but that's it, no other wheel buttons, Airbag light
Dosmastr
Car: 2011 Nissan Rogue SV
Hello Everybody,
I'm leaning towards maybe it's the clock spring but everything I read says that that usually means everything in the steering wheel goes dead. My horn works.
The radio buttons haven't worked for a while. I just happen to notice that when I was checking the code for the airbag light flashing that the cruise control switch is also throwing a fault, And in fact does not work.
The horn works, And all the buttons illuminate when the headlights are on like they should.
Is this still most likely the clock spring?
Rockauto doesn't have any in stock...
What other diagnostics can I perform?
Codes:
B1054-00
P1564
I doubt it's related what the car does Keep insisting it Can't read my key either.
Fuses for the airbag, BCM, And intelligent key, have continuity and look fine
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Clocksprings usually fail linearly across the ribbon, a conductor on one end parts and then the rest follow over time, pop-pop-pop. What you're seeing is typical. It's the clockspring, they just haven't all popped yet.
Dosmastr
VStar650CL wrote:
Fri May 17, 2024 6:33 pm
So last time my blower motor went and I had to remove the gas and brake pedal. This time the clock spring goes and I have to remove the steering wheel.
I think Nissan is just trying to scare me.
I remember you helped me out a whole whole lot previously so thank you for that and thank you for this as well!
VStar650CL
Technical Expert
PS - Your keyfob issue definitely won't have anything to do with the clockspring. If the battery is fresh, try bending the metal fingers on the positive contacts slightly upward to get more spring pressure. On a 13 year old ride, it's also possible your fob just has a dying transmitter.
Dosmastr
What is the magic keyword to get this stupid thing to show up on a Nissan parts website?
I've tried spiral cable. I tried clock spring
Dosmastr
Combination switch body .....
They car has been finicky with both the original key and the knock off the sale guy gave us 5 years ago... Maybe I got iffy batteries idk
I'll try the pins!
VStar650CL
Technical Expert
Nissan steering wheels are easy-peasy, it's the spring-type airbags which are a little dicey. The only hard part on yours is that you may not have the right tool, the bag is held on with torx security screws (T40 I thnk). Make sure the road wheels are straight ahead before you begin. Ground yourself to the chassis to discharge any static before handling the airbag. Once the bag is loose, detach the horn wire and then use a knife-tip to pry up the latches on the bag connectors. They'll pop right out once the latches are lifted. Then there's one nut holding the wheel on. I've only once ever needed a puller for a Nissan wheel, just put some hate into wiggling it and it will pop off. It will already have matchmarks, but they're not usually in an exact line, pay attention to which way it misaligns so you don't remount the wheel one spline off. The biggest thing to remember is to leave the plastic centerlock from the manufacturer on the clockspring until you're ready to use it, so it can't spin accidentally. One turn off center and the new clockspring will snap the first time you turn the wheel all the way.
Dosmastr
Some of these replacement parts aren't even 20bucks on eBay.... Those safe? Lol
Are there certain brands to watch for?
VStar650CL
Technical Expert
I had a cheap eBay clockspring in my old Elantra beater for over four years without any issues. It outlived the poor car.
Most of that stuff is made in China or Mexico anyway.
Dosmastr
So I'm taking off the light switch and wiper switch and there's goo and I mean like a good bit of goo inside the pin connector as well as towards the front where it makes contact with the housing.
Is this supposed to be in here?
The new clockspring is 100% dry
VStar650CL
Technical Expert
Yeah, those switches usually have a crapload of dielectric lube inside to keep the contacts happy. It's normal for quite a bit of it to leak out over time. No worries about that.
Dosmastr
I can see the bearing and its lubrication for the steering column..shaft?
A little bit surprised that doesn't have a cap or something on it
Dosmastr
One of the mechanic videos on YouTube said that the car would need to relearn its steering positioning?
Looks like only one of them said it though I watched like six
Dosmastr
Hey! Very cool now our steering wheel buttons all work again!!
(Not surprised but still happy)
VStar650CL
Technical Expert
Dosmastr wrote:
Mon May 27, 2024 1:17 pm
Technically you're supposed to recalibrate the SAS, but in practice the tolerances on the plastic parts are so close that they rarely change by more than a degree or so. That's well within the ABS's ability to cope. So unless you get an ABS lamp or some weird behavior out of the wheel actuators, you should be able to call it good.
Good work! :dblthumb:
Dosmastr
THE SAGA CONTINUES! :(
Back to the same faults plus one more
B1049 drivers airbag open
B1054 drivers airbag open
P1564 cruise control
Do you guys think the odds are probably I got a not great clockspring replacement?
Didn't check the horn ( Wifie needed to drive away)
VStar650CL
Technical Expert
Dosmastr wrote:
Sun Feb 09, 2025 11:28 am
Yep. The chintz ones are usually okay, but it sounds like you didn't get lucky.
VStar650CL
Technical Expert
On the other hand, now you know how to do the job, and you can go through about 10 eBay clocksprings before you reach the cost of the OE part.
:gotme
Return to “Rogue Forum”
