horn wire!!
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
topherD
Car: 2008 Nissan Versa 1.8S
so i installed a viper alarm a year ago but really only wanted the keyless entry. today i went to wire up the parking lights and horn cause i finally got too annoyed at not knowing if i locked my car or not. parking light was easy, but when i could not get the horn wire right.
i removed the panels and found a harness with a grey plug that has a pink wire. Spliced into that, didn't work. Found another pink wire close-by, spliced, no good. Both are negative, so there shouldn't be any need for a relay. Any help?
topherD
am i being shunned cause i didnt post this under the right topic...or does no one really know the answer???
StammesOpfer
Car: 2009 Nissan Versa SL +Conv Pkg
Well there is a horn relay directly in front of the battery. Service manual labels it H-1... Should just be able to splice in there and activate that relay.
Pin 45 of the E46 wire harness on the IPDM E/R goes to pin 1 on the H-1 relay. That wire should activate the horn. Pages BL-54 and BL-72 (just in case ya wanted to know)
Hope that helps you.
Modified by StammesOpfer at 2:22 PM 7/20/2009
topherD
im trying not to go through the firewall.....so that won't work out. but thank you for your contribution.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
topherD
again thank you so very much for the contribution but i have already referred to that chart.....i located a pink wire that directly affects the horn, so im debating whether whoever wrote up the chart got the polarity wrong? in which case i will have to use a relay =(.
cocainewhite11versa
Car: 2011 Versa 1.6 Fresh Powder
same thing that happaned to me,I put the meter on the pink wire and it has around 2 volts running through it. makes me believe it is positive,think I will try to run a relay and see what happans
cocainewhite11versa
got it,its the pink wire underneath the steering column its a -
topherD
Hey, where under the steering column? i though i had searched everywhere for any hint of a pink wire and only found the ones i mentioned. any way you can provide pictures? thanks.
Return to “Versa Technical Discussions”
