tamdo714 wrote:i changed my battery and we accidently put the positive to the negative, dumb mistake, but now we fixed it and all this doesnt work: head lights don't go up, horn doesn't work, power windows don't work, cluster doesn't turn on, rpm and spd gauges doesn't work. help! what to do thanks?
Done that by mistake and it turned out that I blew the 75A fuse in the fuse block near the battery. I can't get to my car to check but I think it's the ignition fuse. I happened to have an extra fuse block laying around so after I replaced it everything worked just fine. If you can get to a junkyard pull two(keep an extra in the toolbox).
