horn not working
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
larrybarron
Car: 2006 Nissan 350Z
Have 2006 350z. Horn works with alarm and door locks/remote will not work with horn button. Fuse good, relat and horns good. Pulled bags and ran horn too ground. Looking at the wiring diagram it looks like the wire from the horn button is spliced into the wire from the alarm system. Need help
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
larrybarron wrote:
Fri Jan 22, 2021 3:41 pm
Does that mean you pulled the driver airbag and the horn worked when you grounded the wire? Or didn't work when grounded the wire? If it didn't, you have a bum spiral cable.
larrybarron
Pulled Air bag and horn would not work when connected directly to ground
VStar650CL
Technical Expert
Bad spiral cable (clockspring).
Return to “350z / 370z Technical”
