Horn isnt working. Can't find any info. Need Help
jdmz32drift
Car: '93 300zx 2+2
The horn on my 300zx isn't working. I checked the fuse and its perfectly fine. Any other suggestions on how to fix it? Thanks
Srowlands
Car: 1990 300zx TT
Disconnect your horn and hook up a wire from each prong to your battery. If your horn honks then it works and you have a wiring or relay problem. If it doen't, replace your horn. Could also possibly be the horn button in your steering wheel.
SlidewaysZ
Car: z32 2+2 TT
make sure there even hooked up, and make sure the connections arent all coroded. my horn wasnt even connected when i got my Z.
Wetmyson
Car: Z32
SlidewaysZ wrote:make sure there even hooked up, and make sure the connections arent all coroded. my horn wasnt even connected when i got my Z.
i don't think mine is either!!!! and i'm sure it HAS one because i can see it hangin there off the front!!! why would anyone let that go? the horn is especially important on a z because everyone will undoubtedly be in your way!!
