NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri May 27, 2005 5:05 pm
First go through the fuses with the test light. Do this by finding a good graound for the aligator clip, turn the car to the on position, engine running is not nessesary unless you wanna run the A/C to stay cool. take the probe end of the test light and touch the back side of each fuse on both sides, on the backs of the fuses there are small slots you can check for power with out pulling the fuse. It will take you less then a min to test every fuse in both fuse boxs. If you have power on both sides of the fuse it is good, if you have power on one side and dont on the other it is bad. Now be aware if you have no power on either side of the fuse it is not a powered fuse at that point and you dont need to be concerned with it as both circuits you are working on are live when the key is on. The reason I want you to do this first is it may simply be a blown fuse since you clearly have 2 dead electrical components.
If that all comes out ok the pump is mounted on the washer bottle, it should have power at all times and the wiper switch supplies the ground.
The horn if the fuse is ok will need to be tested at the relay. The relay should be gray or black and is 3 terminals inside 2 are parrellel and one is 90 degrees to those 2. The one is power if you put the gator clip on the neg batt cable and the probe of the test light on that terminal your test light should light up. If it does you wanna jump it to the terminal that has a solid green wire under it, NOT the green with white tracer wire, again if all is good the horn should honk. If it does now you need to jump your test light from the power terminal and put your gator on the terminal with the green with white tracer wire and push the horn button. the test light should light up. Those are all the things that should happen , if at some point one of those does not happen that is your problem, when you find it post back your results. If all horn tests come out ok then the relay is no good.
