240addiction »
https://forums.nicoclub.com/240addiction-u8071.html
Thu Mar 06, 2008 10:46 pm
Well at sort of random my horn and Cruise both stopped working at the same time and I am not sure where to start checking. this is on a 91 stock s13. I have checked to make sure each ring on the slip ring has good contact and replaced the relay and fuse under the hood. I checked the voltage at the relay and it is 8.99 volts (or close to that). I also checked to see if the horns worked when they had power applied to them directly from the battery and they did. One night after realizing that neither were working the cruise would work erratically and let me set it once just after starting and driving, but would not let me cancel or resume the setting. I am not sure where to check next. any help would be nice.
ThanksPaul
