kmiles »
https://forums.nicoclub.com/kmiles-u181661.html
Fri Feb 12, 2016 1:32 pm
I'll start off with "I am not an expert here", just offering my opinion. I've done the Morimoto HID upgrade to my headlights and it did not require any adjustment of the headlight aim. If you have the right bulbs, there is only one way that they can be installed correctly and if they are a high quality bulb, the right type and size, you should not have to correct aim. If I remember, the non-HID bulb is an H1 bulb and that is the only HID upgrade that you should use in your headlight. You are also correct, there is no auto-leveling on non HID systems. Before messing with your headlight aim, be sure you have the correct bulbs, correctly installed in the enclosure.
