Hopping Rear End?
1234go
im new to independent suspension, formerly i just drifted my corrola with the solid rear end. I noticed, for example, a dounut, after i disengage the clutch, my rear end "hops". could you help my out? i have a s14, stock vlsd, and tein hyper flex coilovers. this doesn't seem to be a problem when i have speed, but more just at stand stills or launches, any feed back would be much appreciated, like common problems, and the fix. thank you
danielwka
Car: 1993 240sx SE
I can't say for sure about the s14 but the s13 has problems with the soft subframe bushings going out. My s13 rear end hops whenever I accelerate too hard into a corner. Check the bushings that connect the subframe to the chasis, one of the most common suspension fixes are subframe spacers.
turboboost
Car: 1990 nissan 240sx coupe,1990 240sx hatch,
to get rid of that porblem just get subframe spacers.....they are really cheap and easy to install
