There is no real law stating you can't have a RHD car state side, there are however strict regulations on how soon the car can be allowed in the country. This is a july 89 and just this month turned 25 years of age and is now federally legal to own and drive on the roads as that is when it becomes exempt from both DOT and EPA regulation. My husband likes to joke about me becoming a postal worker, as all of their vehicles are RHD.Cams wrote:Hi Gabby, indeed, sweet R32 you got there! Lucky car, I must say, as it fell on very good hands.
As my wife drives a RHD Mitsu, are RHDs allowed to circulate in the United States? Just wondering.
thank you. She was a little rough paint wise when we got her from the Auctions in Japan. Had it painted LP2 in June just before it got shipped.Sideways s12 wrote:She is a beauty! can't wait untill I get mine!
Me too, can't wait to install the Greddy coils, ARC sways, and Blitz FMIC among other things to really start tearing up some pavement.float_6969 wrote:Man, I love R32's!
Does it have the turbo ECU and the turbo airflow sensor? Isn't it the N/A by any chance? Maybe it's pegging the VAF. Any possibility to check the output voltage when the fault happens? When does it lean out w/ regards to the the fuel cut?ca18detgabby wrote:UGH, spent all day with the car today. Cleaned all the injectors and even hard wired them to the battery to see if we could get them to flow carb cleaner properly. They all work. We smoke tested it, found a pair of small leaks, sealed them up and still this stupid thing is acting like it is hitting fuel cut. Runs great, but when it reaches .3 bar the car totally cuts power and falls flat on its face. Seems we have narrowed it to the ECU, literally the only thing left we haven't changed.
yep the ECU is a Turbo FJ ECU (pulled the ECU out and cross referenced the # vs one on YAJ) and the VAF is showing voltage properly. We even pulled the cover off to make sure it didn't have a modded spring or anything as reading showed that in the older days guys would use this to modify metering. It was all stock inside. We even checked to see if the ECU had an Eprom chip that was maybe tuned for something else. We even cleaned and lubed the Flapper within the VAFS to make sure the door wasn't sticking as some people had experienced similar issues with that.blownhemi wrote: Does it have the turbo ECU and the turbo airflow sensor? Isn't it the N/A by any chance? Maybe it's pegging the VAF. Any possibility to check the output voltage when the fault happens? When does it lean out w/ regards to the the fuel cut?
If you know how to do the CA ECU conversion, I'd go ahead ASAP, regardless.
Congrats on the R32. The most beatiful piece of the R line.
Did you check pressure on the fly, or stationary, at idle? What FPR are you running? Was it also among the items that were replaced with a known working one?ca18detgabby wrote:Fuel pressure checked with fuel pressure gauge
Yes, it really seems so, as if it's one of the trivial things, but it also seems like you've covered all of those.ca18detgabby wrote:We have been reading about doing an CA or SR or even KA ECU conversion, just a matter of willingness to invest more time and money into something that seems so close to working.
Fuel pressure as checked Post Walbro (45PSI IIRC), it was also checked at the FPR both flying and at idle as it was assumed that the fuel was the issue. The FPR is the factory FPR from the FJ20. it is one of the few items we haven't replaced, but it shows no signs of needing to. We even tried removing the vacuum source from the FPR which from reading should bump the pressure 10PSI @ the rail. None of this improved or changed anything.blownhemi wrote: Did you check pressure on the fly, or stationary, at idle? What FPR are you running? Was it also among the items that were replaced with a known working one?
normally between myself and my husband we can sort through these issues w/o even seeing the car. Regardless of make and model fuel/time/air, we can figure out most anything. This has become a real quandary among my gear head friends as all of us are left with.... well we fix this so it can't be that. The only other thought is that something replaced with a "good known working" component isn't as "good" as we thought.blownhemi wrote:
