When I was younger I spent many nights drooling over the awesome episodes of InitialD, an animated series, I am sure many of you are familiar with.
Naturally it sparked my interest in drifting, and the transformation from DSM fan, to a fan of any and all imported FR platforms begun.
After tinkering on two different n/a 1g's, one 1g gs-t, and one n/a 2g, i was finally came across a clean/ ghetto z32 that i was lucky enough to swap my second gen eclipse for.
After being young and dumb and learning the hard way a couple times, I got rid of my z32 to start a project I can drift legally on a track.
I had originally intended on swapping my ls1 into the s13 coupe I picked up from a friend, but I came across another shell (s13 hatch) that I decided would be a more suitable candidate to accept the ls1.
This is the start of the very slow going process of building my first drift car. With high hopes, and a mind filled with countless hours of research, I ended up using the money I had acquired from selling my z32/old ls1 to pick this beaut up from Hawks Third Gen.
After months of being super busy at work I finally got some time n tore into it to freshen it up a bit.
Here's a list of what all I did to the new LS-
TSP 224/228r 114lsa cam
ARP cam bolts, and head studs
Cheverolet performance MLS head gaskets
COMP Magnum Chromoly pushrods
SLP double roller timing chain
SLP oil pump
GTO oil pan
Improved racing GTO oil pan baffle
Ported/ polished casting 241 heads, with lunati gold dual valve springs
and Tick Performance knock sensor upgrades
I had also purchased a Chasebays s13 Ls1 harness, and some other parts to hopefully make the swap easier, like a Sikky 32mm sway bar,and the Wilwood CMC kit from Sikky as well as their power steering lines.
For mounts I will be using the kit from Hooker Headers, that used Creative steel C5 Corvette motor mounts and a Prothane bushing for their T56 S chassis crossmember.
The only modifications to the shell i have done so far, would include installing a Walbro 255 LHP fuel pump, gutting the interior, and installing the Sikky front sway bar. I have also bashed out the transmission tunnel a bit to clear the T56, and cut out the inner fenders to prevent rubbing when she gets low.
The shell already had projector headlights, z32 front calipers with stainless steel braided lines, z32 BMC, drilled/slotted rotors, and tension rods (that I am unsure of the brand) installed when I picked it up.
The rotors it came with on the front already have both 4x114.3 and 5x114.3 lug patterns, so i will be purchasing the 5 lug hub kit from Ichiba soon after she runs (assuming that things will work out).
Just to clear things up before I get too far into it: This will definitely NOT be a very clean build as I am on a budget, and will be trying to get it together as soon as possible to have it ready for the 2014 season.
Anybody can bash on me as much as they want about it, but I am merely trying to build a fun, easy-to-drift s13 that i can put through hell learning how to drift, and not feel bad about it.
- Pretty can always come later.
